AVS › AVS Forum › Audio › DIY Speakers and Subs › LMS Ultra 5400 voice coil
post #1 of 5
Hi,
I received my LMS Ultra 5400 earlier this week, but I noticed a weird gap in the "pipe" inside the voice coil, it doesn't wrap completely around.
As I don't really have much experience with subwoofer drivers I don't know if that is normal or not. Should I contact TC Sounds about it, or is that gap supposed to be there?
post #2 of 5
Originally Posted by harrikuk View Post
Hi,
Supposed to be there. If it was whole it would have higher back EMF as it would be a solid circular conductor.
post #3 of 5
Mine has the same. I have had no problem whatsoever.
post #4 of 5
normal.
post #5 of 5
Thank you very much for the information, big relief
My plan is to build most likely a ~85-100 liter sealed box for the sub. But I'll borrow an existing suitable thread (or make a new build-thread) once I get those designs sorted out.
