Originally Posted by kwarny
Not even a thank you for that chart
(is the harmonic distortion below the threshold?). I now have to send my amp back to Brian and build a new enclosure with another alignment? The steady-state signal was also louder than the max burst that I listen to during music. I live in an apartment so I have neighbors. In my case, accelerometer servo main benefit matters only when I listen to content much louder than I am able to for a fraction of a second? Even if I could do GP measurements, the results will never be apples to apples. If you want apples that we can put into the same basket, we can arrange for you to temporarily send a DD-15+ over for the testing. What I nitpicked was over the port tuning and from the same reviewer. As stated earlier, the op wanted to know the benefits, then the conversation turned for some reason.
I recommended for you to perform the Klippel tests so you could determine what levels matter to you.
We only listen to content for 6 seconds? The spectral artifacts are also masked. You will have to find the early customers that compared the non-servo version to the servo version with a matched close mic response.
What country do you live on? There may be a rythmik somewhere near you.
(is the harmonic distortion below the threshold?). I now have to send my amp back to Brian and build a new enclosure with another alignment? The steady-state signal was also louder than the max burst that I listen to during music. I live in an apartment so I have neighbors. In my case, accelerometer servo main benefit matters only when I listen to content much louder than I am able to for a fraction of a second? Even if I could do GP measurements, the results will never be apples to apples. If you want apples that we can put into the same basket, we can arrange for you to temporarily send a DD-15+ over for the testing. What I nitpicked was over the port tuning and from the same reviewer. As stated earlier, the op wanted to know the benefits, then the conversation turned for some reason.I recommended for you to perform the Klippel tests so you could determine what levels matter to you.
Sorry no cigar for that chart. You did it at 70 Hz where cone excursion is small and power would be low !! What's the point of that ? It's when the driver is pushed to its limits is where you need the servo the most and that means low frequencies and high power !!
I'll wait for the tests of the sealed box version to appear in home theater but I note they have never done a review on ryhthmik. I wonder why ?
Also the power compression over time due to voice coil heating is not going to be nowhere near as objectionable as distortion caused by non linearities in the motor system.
But don't get me wrong. After all of the negatives I have said regarding this device if you read the patent on this invention you will find that rythmik has taken an original invention from the 80's and improved upon it, the main benefit of it being it's immunity to changes in voice coil resistance. But the original device was never referred to as a servo system. It's because rythmik modifies the design by the use of velocity feedback is where the 'servo' terminology has crept in even though the behaviour is more similar to that of the original invention and not to a traditional servo based system. And because the sense coil shares the same magnetic circuit as that of the main driving coil it is plagued with all of its problems as well and no quick fixes !
