I'm putting a home theater system into my 18'x14' living room, which is part of a small (1200 sf) house. There's not an obvious place to put a subwoofer that won't stick out like a sore thumb (I'm married, so need to factor that in
). Is using an in-wall subwoofer a good option for this size room? Or will it shake the walls, and therefore my house given its size? The shop I'm dealing with is recommending the Velodyne in-wall sub, which apparently is designed to reduce rattling, but I'm not sure if that's true or just a marketing pitch. Does anyone have any advice on this or experience with the Velodyne?
). Is using an in-wall subwoofer a good option for this size room? Or will it shake the walls, and therefore my house given its size? The shop I'm dealing with is recommending the Velodyne in-wall sub, which apparently is designed to reduce rattling, but I'm not sure if that's true or just a marketing pitch. Does anyone have any advice on this or experience with the Velodyne?Thanks!
