Hi,
I bought this cable:
http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OC:US:3160
When I connect it to my XBOX 360 the screen is blank. When I connect the cable to another HDMI equipment it works, and when I connect the XBOX using another cable it also works, therefore both the cable and XBOX are OK. Could this be some compatibility problem between the XBOX and the cable? How can I fix it?
