AVS › AVS Forum › Audio › Speakers › Matching a center to existing Dali Mains
post #1 of 4
Hello all !
I own a pair of Dali Suite 2.8 mains which I bought 2nd. hand, which sound good for my personal taste.
As for now, they are being forced to cooperate with a rather old Energy Center, which cannot match their capabilities in power, let alone timbre match.
Since the Suite Series is long discontinued, and since it is very rare in 2nd. hand, I'd like those of you who are familiar with their rather unique sound to recommend an alternative Center to listen to, with Dali or any other Brand.
Thanks !
Ori
post #2 of 4
It looks like the Lektor LCR will be your closest match.
post #3 of 4
Seems a bit under-qualified, isn't it ?
post #4 of 4
Just to through one out there and it isn't cheap but look at a Dali Helicon C200 center channel and see if that might meet your needs, but yes that is a tough situation to find a replacement for that set, and good luck with it.
  Back to Forum: Speakers
