Just read something interesting. Most likely bogus. Can someone decipher this.
CRT screen flicker causes switch to low alpha state. Flicker occurs in a CRT because the phosphor dims while waiting for the next pass of the electron gun.
LCD screens don't have that flicker because the lighting is done at the pixel level by turning the grids' transistors on and off simultaneously. Videogames are another matter as the framerate of most games is 30 hz. A crt is 60hz while a lcd computer monitor is 30 to 80 khz
LCD tv's go up to 120 hz. The high frequency flicker of lcd's may be worse then the low frequency flicker of CRT's. Increased resolution is supposed to worsen flicker. LCD's have a higher resolution. Dim room lighting makes it worse.
Plasma Tv
Every single pixel in a plasma screen television is it's own little fluorescent light bulb. Each of those 'bulbs' flickers at around 120 Hz 100 Hz is well within the range which can be considered a "Strobe Light" capable of inducing a hypnotic Alpha state in the brain
Plasma Tv
