Hi all. I'm finally going to start ripping all of my BD discs (250 or so) to my iTunes server for playback on my 4 ATVs. Two of my displays are still 720p but they are excellent 720 displays and not getting updated any time soon. Even though some of the purists here are going to cringe, I wish to encode the BDs to 720p.......the reasoning being the smaller file size and two of the ATVs are wireless. I want to be able stream the BD files to all of the ATVs reliably and none of the displays are close/critical view distances so discerning between 720 and 1080 isn't that easy anyway.
Now after researching the topic on the Handbrake forums, i've created the optimal preset for my needs BUT the encode times are just waaaay to long at over 9hrs for a 2hr movie. I think it's time for a new ITunes server build. My question is what processor would make quick work of these encodes but not break the bank. I'll be building from ground up and don't need any special graphics on the PC itself as I don't watch movies on my PC. On board intel 3000 should be more than enough. Small form factor isn't an issue either as I have a nice Mid tower case. My other needs for this PC is a good optical out for critical 2 channel audio listening.......I do this almost exclusively at my desk. I do also work from home from time to time using Photoshop for marketing and Excell for accounting. So some recommendations for components would be very helpful. Please consider the critical audio part.......less noise the better. I use a high quality optical cable to send feed audio so Interference isn't an issue here but jitter on the PC side is. Thanx .
