AVS › AVS Forum › Video Components › Home Theater Computers › Is HDMI audio available for HDPC?
post #1 of 9
I Plan to build HDPC to be used in my HT. Is HDMI-audio available for PC yet?
post #2 of 9
Yes. It has been for at least two years using intel CPU/GPU's.
post #3 of 9
Nvidia and ATI as well.
post #4 of 9
Yes and I believe that was as early as Fall, 2009.
post #5 of 9
Thank you sammy2 and lockdown 571.
May I ask you more? Is it possible to split HDMI-video and Hdmi-audio in HDPC?
I want to send the HDMI-Video signal directly to projector and HDMI-audio signal directly to the pre-processor.
post #6 of 9
This is exactly what I do with my Asus HDAV Deluxe and AMD 4550 video card.
Connect hdmi out on video to hdmi on the plasma. Connect dvi out on video to hdmi in on HDAV, connect hdmi out on HDAV to avr.
The tv is display 1 and I extend the desktop to my avr which is display 2.
post #7 of 9
Can it send DTS-HD signal to avr?
Form whatI know, HD track can only be send via HDMI. not DVI.
post #8 of 9
You heard correctly. That is true for all sources, so if your receiver doesn't connect with HDMI you need a new AVR. This is not an issue that is the fault of a current HTPC.
post #9 of 9
The HDAV can send DTS-HD and TrueHD to your receiver via hdmi.
DVI does support audio as long as the manufacturer implements it.
