Hello I have never built my own subwoofer before and was looking at building my own. After a little bit of research I have a couple ideas that I had in mind.
Since this would be my first build I was thinking of building a sealed sub because of its simplicity and I don't have a lot of woodworking experience. I saw a guide on how to build a sealed enclosure for a 15" driver from this website. It is approximately a 100L enclosure.
http://www.danmarx.org/audioinnovation/tc3000.html
I really can't go too much larger than this because of space requirements the only thing would be is that I could make it a little taller. I would also like to keep it at 1 sheet of MDF because I also don't want it to weigh a ton.
The driver I was considering buying was the Dayton Audio RSS390HF-4 15" Reference HF Subwoofer.
http://www.parts-express.com/pe/show...number=295-468
And the amp I was considering was either the Bash 300W
http://www.parts-express.com/pe/show...number=300-750
or the Bash 500W.
http://www.parts-express.com/pe/show...number=300-752
I would prefer to go with the 300W since it is cheaper but if I would need the 500W I could get it. Also if there are better options than the bash amp for around the same price I'm all for it.
I was wondering if these were good choices for a first build and if the enclosure was big enough and if the sealed enclosure is the best option for that driver.
The use would be 60/40 movies/music. I also was messing around with winISD to graph a model, but don't really know what I should be looking for.
Thanks for any input/help.
or the Bash 500W.
