Wow, now I am really confused. I have a V673 arriving on Wed from EE. I got looking at the manual for the V673 figuring I would get ahead of the game and when I looked at the TV connection apparently I need to hook up an optical cable between the TV and the receiver since my Sony 46XBR2 is not ARC capable. I thought that everything went into the receiver from the DVD, XBox, Cable Box via HDMI and I just needed an HDMI from the receiver to the TV. What is the optical cable for? I thought that the HDMI carried both video and audio. I can hook it up the way it says in the manual but I have no idea why it needs to be so. My guess would be that if I wanted to play music from a CD player or Apple Airplay through the TV speakers??? Why would I do that when I have a receiver with surround speakers? Any quick words of wisdom/explanation?
post #241 of 1920
8/20/12 at 2:59pm
It may be further explained later in the manual but I have not gotten that far. My TV does in fact have an optical out but is not an internet capable TV. I think that the rest of it should be straight forward on the connections. I am a little concerned about getting the Airplay and internet connection going but I will take that on when it comes. I have an iMac an am crossing my fingers that it will make the Airplay setup simple. Based on what you said, I think that I am going to pass on hooking up the optical cable as I do not intend to connect anything to the TV directly. It will all go through the V673. Thanks again for the advice/help.
