Originally Posted by DeadEd
OK, I'm wondering about this too; glad I'm not the only one. I've been reading the manual. Right now all I have hooked up is a center (Polk), two fronts (Boston Acoustic towers), and a Polk subwoofer. It does not want to use the subwoofer. I don't get it. When I look at the manual it shows in the diagrams that the subwoofer is on even when listening to Net radio. The only way I can get it to turn on is by playing the BD/DVD. But even when I stream Pandora through the DVD player it does not use the subwoofer. I tried going to speaker setup and tried the tone testing. I have the subwoofer on, plugged into a single 1-SW out. But even on the front panel display on the RXV673 it shows that it is not using the subwoofer.
Why? What am I doing wrong? I tried playing with the 'Scene' buttons and some of them turn off the center speaker, none turn on the subwoofer. I'm stumped.
Anyone have any ideas?
**NO SOUND FROM SUBWOOFER ANSWERED**
It seems that answering my own questions is becoming a habit. Sorry to be such an idiot. I'm very new at this HT stuff. My understanding of this now is that the subwoofer, when hooked up through the LFE input, works only when stuff is encoded with LFE, such as in movies or HD radio. What you want to do, Kainan, is turn on the Extra-Bass option and turn up the crossover on the back of the subwoofer. I did this and now it works great. To do this, press the ON SCREEN button on the V673's remote and select setup, then select CONFIGURATION. I assumed you already turned the subwoofer on in this menu. Below the subwoofer is an EXTRA BASS option. Turn this on. Now my subwoofer works fine and the music is much fuller. I hope this helps others.
