AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Stupid question regarding speaker wire...
Stupid question regarding speaker wire... - Page 7
post #181 of 206
Originally Posted by Ratman View Post
Click the (1) .
I did that before asking. It brought me to a page that looks to be a history of closed classified ads.
Is it a rating, a page number??
j
post #182 of 206
j
Click again, look closer and you will see:
Positive Feedback: 100%
Total Positive Received: 1
Members who left positive: 1
Total Neutral Received: 0
Members who left neutral: 0
Total Negative Received: 0
Members who left negative: 0
All Feedback Received: 1
Submit Feedback For:
Randy Bessinger
I'd assume only one feedback score was provided out of three ads and not a page number.
post #183 of 206
Originally Posted by Chu Gai View Post
The ignore function forgot my birthday last month. Some friend!
You didn't get the present I sent? That darn post office....must be their lack of funds.
post #184 of 206
Thank you..
j
post #185 of 206
And taken further, it means either two of the three never resulted in completed sales via this AVS forum, or, he sold all three via AVS, but two of the three just didn't bother to leave any feedback. Which isn't uncommon, if you've ever sold items before, whether it be on Ebay, Amazon, Audiogon or some other forum.
If our resident forum genius couldn't piece that together on his own, that must make me a SUPER genius!
That settles it. I'm going shopping for velvet-lined pocket protectors this afternoon. My diamond-encrusted protractor deserves the best.
post #186 of 206
Everyone on AVS is of genius IQ.
post #187 of 206
Never bought or sold on any of those..never even looked before. If I needed to do that, I'd get one of my kids to show me how.
Oh yah...where's your super-duper decoder ring..
Look Duuude..Don't you DARE diss the pocket protector. And, what's a protractor
cheers, j
post #188 of 206
It's an adult pacifier for us genius types.
post #189 of 206
Waaaahh. I miss mine..
Been using a 12 inch digital angle rule I picked up from Klingspor's bout a year ago. The silly thing measures to .05 degrees.. Man, that's nuts.
Next will be an INCRA miter 1000HD.
j
post #190 of 206
post #191 of 206
Great thread derailment.
That..Oh, that's easy to fix..
Originally Posted by arnyk View Post
IME this is a two-way street. IME, once the test bench is set up so that it doesn't add any grounding problems, it may actually be more favorable to the UUT's with grounding problems than real life.
I believe this is one of the most significant milestones to come out of this thread. The agreement that there is the possibility of a UUT measuring one way on the test bench, and another way in the field.
This has the implication that two devices can measure exactly the same on the bench, but sound differently at the user's location.
So despite the fact that both devices have can have the same measured specifications far below what is considered to be human thresholds, actual useage could possibly present differences..
Hmmmm.
cheers, j
post #192 of 206
Back to the OP...
Does "directionality" matter with speaker wire?
The concise answer would be a new milestone.
post #193 of 206
Back to the OP...
No, speaker wires are not directional.
Happy to oblige you.
post #194 of 206
Wire coat hangers are!
post #195 of 206
Then why don't they have arrows?
post #196 of 206
Because they are chiral.
post #197 of 206
You mean, as opposed to what happened 140 posts ago??
Obviously, you have a thing going for me, disguised as a "content/thread police thing". When were you voted grand poobah??
Back to the OP...
140 posts ago, it was already answered.
So you enjoy dead horses?
j
post #198 of 206
Why arrows?
The same reason we have arrows on the road for idiots to know which direction to go.
And you thought all electrons were created equally smart !
post #199 of 206
I do a lot of lamp repair and was searching cyberspace for references to corrosion in lamp cord when I came across these posts on this website. I frequently replace lamp cords that are corroded under the insulation along their entire length. This is almost always found on inexpenvive Chinese? "throw away" (cheaper to buy a new one than have it repaired) lamps. This corrosion is a HUGE problem since as the copper corrodes and is replaced by corrosion product there is less copper to conduct the current and overheating of the wire can occur resulting in failure or fire. I am thinking it must be due to sulfur in the insultion. Big, big problem!eek.gif
post #200 of 206
You see enough corrosion to cause wire heating to fire/failure? That's a lot of corrision... Not disagreeing, just surprised. Most of the time I have seen problems it's at the connections even if the wire is green up and down its entire length.
post #201 of 206
we live in the internet age... i am relatively confident that if "cheaply wired chinese lamps" (i.e. only 99.999999% of the lamps sold today rolleyes.gif ) were causing house fires, it wouldn't exactly be a well kept secret...
not to mention all those chinese made extension cords that would also be an issue...
post #202 of 206
Originally Posted by lamphunter View Post
... This corrosion is a HUGE problem since as the copper corrodes and is replaced by corrosion product there is less copper to conduct the current and overheating of the wire can occur resulting in failure or fire. I am thinking it must be due to sulfur in the insultion. Big, big problem!eek.gif
I have seen surface coating on copper wire but never enough to reduce the gauge enough to matter. I don't think copper can do this, unlike steel or iron will.
post #203 of 206
Normally the corrosion stops once an initial layer has formed as it blocks O2 from reacting with the layer underneath. I think. Been decades since my inorganic chemistry classes.
post #204 of 206
Back in early 2000 I wired my prior home family room for 5.1 sound, running the 12/2 wired under the room via basement and then coming up at each speaker location.
All open space in the basement, no in-wall, just basic 12/2 wire.
I ran out of wire, went to local Lowes and they had a different supplier for the wire, it was 12/2 but thicker outer jacket, anyway I bought a 250ft spool of it.
Fast forward, I used that in my new home family room home theater, and it did oxidize over the years. frown.gif
(I took these pictures back in Feb-2010)
Guess what, the speaker still work fine, sound fine, and what not.
I've since used most - not all - of the remaining 12/2 wire on that spool for my outdoor HT set-up.
You can clearly see the "green" 12/2 vs the normal 12/2 - both bought circa 2000, hey gotta use it since I own it.
I've since used the remaining 12/2 length of that "bad batch" to extend speaker wires as I relocated some in ceiling 2' x 2' tile speakers in my basement when I got a pool table just a few weeks back.
Just cleaned up the oxidization, soldered them to the existing 14/4 wire there (more leftover wire from the HT project), and it works fine.
post #205 of 206
I've had similar situations where the wire got ugly and green. I've seen it happen to cheap wire and expensive wire. The first time I saw it , this was a roll of upscale Monster Cable.
Clean the strands up with fine sandpaper and it gets bright as new, and solders and hooks up well. A good electrical connection is gas-tight and this tends to keep the problem from recurring where it counts.
post #206 of 206
Originally Posted by Hyfi View Post
"Be aware that besides all technology, all measurements, all computers, and all theories; The human ear is so much more sensitive than ANY measurement instrument in the world"
The human ego is so much more sensitive...
FTFY
