AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Connecting NetFlix to My HDTV & Blu-Ray Player?
post #1 of 6
Okay so I finally got a Panasonic DY-WL10 Wireless Adptor for my TV: Panasonic VIERA TC-P42S30 42-Inch 1080p Plasma HDTV
It did not come with a owner's manual, because I got it on Ebay.
So please help me out guys.
I put the adapter in the USB port on my tv and I connected it to my wireless network.
Than I clicked on NetFlix and this message pops up,
"Connect the TV to your router with an ethernet cable or the compatible Panasonic wireless adapter.
Run the "Connection Test" under the network settings,"
I tried connecting to my wireless network again and this time I got an error.
Thanks in advance
post #2 of 6
Thanks in advance
Did you run the connection test ?
post #3 of 6
You can download the Owners Manual from Panasonic's website.
post #4 of 6
I did
post #5 of 6
Anybody?
post #6 of 6
Make sure you have the right one. I have a GT30 and an X3, and WiFi adapters are not inter-changeable. I had an extra GT30 adapter and it would not work in my X3. Same model year, 2011. Had to spend an extra $50 for the other adapter for the X3. Hope his helps.
