AVS › AVS Forum › Audio › Receivers, Amps, and Processors › AVR - Sub amp not working???
post #1 of 2
I have a Yamaha VX-R867 receiver with a pre-out for the sub going to a Buttkicker amp to power the SVS CS-29+ sub
it worked fine in the past, now for some reason the pre-amp light stays red and nothing goes to the sub
I've tested the sub woofer works (hooking it up as a speaker)
and have tried the test tone in the AVR setup menu , but still the amp stays with the red light and no sound from the sub
It was working fine before, and then I moved things and rewired (but as I've said I've double checked the wires to the sub, and also have double checked the coaxle calbe going from the AVR sub pre-out to the sub)
Any ideas?
post #2 of 2
My sub output on Rx-V667 went out within 3 months. Called Yamaha...said i got a bad unit and recommended that i take it to the nearest repair center...( disappointed in the yamaha...
