The door is the weakest link in the soundproofing efforts. I have dual walls but I couldn't sell the dual communicating doors idea to the Mrs. Here's a crazy design I came up with that involves only opening 1 door but still incorporates the 4 pillars of sound isolation:
M- Mass: Total of 2 door slabs and 1/2 MDF
A- Absorption: 3" of pink fiberglass between layers
D- Damping: Layer of green glue
D- Decoupling: Isolation clips and hat channel between layers
Could this work or am I kind of nuts....don't answer that. After some quick math this assembly should be well under 300lbs which is less than some other designs I have seen. It is kind of thick at 6.5" so would certainly need some type of custom handle assembly.
I am doing fabric walls so I would have fabric covering the inner door wrapping around to cover the gap between the inner and outer doors. The outer door would be finished to match the rest of the basement.
Side View:
Bottom View:
Side View:
Bottom View:
. Any reasonable way to mitigate that risk?
Keep your sewing kit handy too.
. The torsion box idea sounds interesting or maybe replacing the inner door with something like steel?
