Someone is confused, and they are likely confusing the maximum load permitted on a branch circuit by the National Electrical Code (which is 80% of the branch circuit rating) with the rated capacity of the branch circuit itself. That has nothing to do with any characteristic of the surge protector itself; the same "80%" rule would apply to a cheap power strip with no surge protection, or even the total load of all connected devices. So yes, don't exceed a continuous 1920 watts on that 20-amp branch circuit, but not because of the surge protector.Originally Posted by Cigarjohn47
P.S. On another note; as I've talked to my electric company and many different surge protection companies, they told me that when you connect a surge protector to any of your homes outlets, you will not get the true amps that outlets is setup for. For instance, a 20 amp outlet with a connected surge protector will be reduced to 16amps and a 15 amp outlet will be reduced to 11 total amps. So be careful not to overload your outlets and play it safe by installing 20amp our more amp outlets so overloading doesn't occurr. At 20 amps; technically it should provide up to 2400 watts of power. But realistically, if a surge is connected to a 20 amp outlet, you will be getting a maximum of 1920 watts. Anyway, good luck once again with everything.
![Wow: World of Wonder [Blu-ray]](http://cdn.avsforum.com/1/11/50x50px-ZC-1166fb14_B00462PTDQ-51E0ByQYHsL.jpeg)
. Was just reading the comments about the buzzing, especially on white screens.
If I mute the tv and find a bright screen I can discern it.
