AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic VT50 owners thread
Official Panasonic VT50 owners thread - Page 373
post #11161 of 12310
Originally Posted by luvthefloyd View Post
Well i have a GT50 so i have a sense of what it should look like when it's functioning properly. The colors are basically massively out of whack with lots of halos in the dark scenes. Just doesn't seem like a settings issue.
Do you have the TV hooked up via component by any chance?
post #11162 of 12310
Nope HDMI in both cases
post #11163 of 12310
Ok. If you don't match red, green and blue up the colors would be way off like you have described. I hope you get it figured out, good luck.
post #11164 of 12310
Thanks. Going to give panasonic a call in the morning,
post #11165 of 12310
Would suggest that you reset to the factory defaults and try again.
post #11166 of 12310
I don't trust "price drops." Best Buy had the 65" VT50 "on sale" (about $400 off MSRP) ending Dec 31. Went back after the 1st and it was lowered another $400. Go figure.
post #11167 of 12310
Originally Posted by dftkell View Post
Hello everyone,
I about to buy the VT55. I was going to purchase my mount from Parts Express. I've bought several in the past and they're a great value.
My question is, can I buy a mount that brings the TV close to the wall? Or will that not work because of the power cord?
Anyone with experience on this? What mounts do you recommend? I don't need a tilt, fixed is fine.
Dan
I have my vt50 wall mounted using this one from Monoprice. http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082812&p_id=5918&seq=1&format=2
It's a nice mount, and has a built in level.. it brings the tv about an inch and half from the wall..The power plug does stick out a bit but this mount clears it fine without any mods..
post #11168 of 12310
I know running the slides for "aging" before calibration isn't always considered necessary by most, but I plan on doing it when I receive my ST50 in a couple days just because I'm overly cautious with anything that costs me more than $30. I have one question though, will calibrating the TV before running slides for a "break in" period make any difference to the end result? Is there a reason you are supposed to "break it in" BEFORE running them?
post #11169 of 12310
Greedings from finland!
I just bought EU version of tx-p65vt50e and now i'm shocked.
What have they been thinking whn locking "panel brightness" low on eu models without posibility to adjust it??
Is there any way to force Us firmware to Eu model or "unlock" setting from service menu?
I spend last night calibrating tv and result is fine except picture is waaay too dim.. Very very dissapointing.
post #11170 of 12310
I dont think they had a choice with energy requirements in certain countries. Panasonic EU and Panasonic NA do things completely different and do not answer to each other.
post #11171 of 12310
A plasma changes most rapidly when it's new. If you calibrate before you've used the TV for a reasonable amount of time, your work will be effected by those changes. That's costly if you're paying for a quality professional calibration. If it's just your own time, I'd wait anyway. What's the rush?
By "them" are you referring to the slides? The only reason for running the slides is to mimic D-Nice's exact procedure if you are going to use his settings. One thing is almost certain, if you go into the menus for an extended period of time to adjust your settings, there is a good chance your screen will retain the word MENU for a good while. eek.gif
It's almost 2 AM where I am, so I can't go into more detail. It seems to me that there is some confusion about what the slides are for and what "break-in" refers to. In fact, there is nothing wrong with using your TV for a few hundred hours before you worry about calibration or changing settings. Just be sure to mix up the type of source material you watch, and avoid leaving the same fixed image on your screen for long periods of time. You can also hold of on the brightest mods too.
Edited by htwaits - 3/19/13 at 1:58am
post #11172 of 12310
You should have been able to get a check for $400 then.
post #11173 of 12310
Originally Posted by DWBoston View Post
Attached is my calibration report. DW - AccuCal Audio Report.pdf 449k .pdf file
Are the settings the default settings in Jeff's pre calibration report?
Anyway my point is that these VT50's in the right modes are fairly close and for the most part within specs.
Look at the pre and post numbers and grafts, not a big difference. And Jeff as always did a nice job with your calibration,
ss
post #11174 of 12310
Panasonic support answered pretty fast.
They said that limiting "panel brightness" setting in safety precaution, because this setting could damage panel if handlet without care (WHAT?)..
Support tech also said that pro calibrators have access codes to adjust panel brighness on EU models? So if there is such code, could someone (ProCal with codes) PLEASE pm it to me.
If panel brighness could damage plasma panel, why setting in availeble on us models? Maybe panasonic has decide that we (european idiots) are too stubid to handle our plasmas.
post #11175 of 12310
Ours may be brighter than the EU displays, but you're still likely to want them brighter for a bright room setting.
I'm still hoping that someone would find a hack to the ABL (automatic brightness limiter).
post #11176 of 12310
Originally Posted by slimrn View Post
How about a Bluetooth keyboard?
Sorry for the late response if someone already answered
I got a Bluetooth keyboard that is advertised in the Viera store, it functions fine, except that our tv's dont support the mouse function, so the track-ball feature on the keyboard is inoperable
The trackball does work when the keyboard is hooked up to my ps3, so I do know it works
Edited by billmich - 3/19/13 at 7:01am
post #11177 of 12310
For some of the Vierra apps, I can use the voice recognition on my iphone 5 to fill in the blank before transmitting it on the home network.
post #11178 of 12310
ss
I was using the D-Nice recommended setting following 120 hours of panel prep with the slides. You're right that there doesn't appear to be a huge difference in the graphs, but the picture is noticeably better post-calibration. Prior to the calibration, skin tones looked very red and unnatural to me, and now they look normal.
Over the weekend I had my first experience with noticeable IR. I was watching the Golf Channel and NBC coverage of the PGA Tour event in Tampa for a few hours. The two channels use a combined GC/NBC logo, which was noticeable onscreen later when watching other channels. I put on a couple of full screen HD movies on channels with no logos (and ran the scroll bar once) and it is fading.
post #11179 of 12310
I have the viera app on my iPhone 5, but couldn't get the keyboard to transmit to the TV. What I missing? Everything else seems to work as far as I know except the keyboard.
post #11180 of 12310
Do you have your phone on a wireless home network?
post #11181 of 12310
Ok so my pink screen has at least temporarily been resolved. Btw I also had that terrible buzzing fan like noise when it happened. I called Panasonic and they had me do a factory reset and it completely fixed everything..... But why did it happen in the first place? Bought a 3 yr square trade warranty just in case.
post #11182 of 12310
Can someone enlighten a fresh starter whether modern HDTV plasma panels are capable of reproducing AVC-encoded video with 10-bit profile (from PC)? My understanding is that currently there are only few PC monitor models on the market that are capable of doing that... or else I'm very much mistaken?
hf
The reason I'm asking is because official specification for VT50B model sheds no light on such technical intricaces whatsoever, albeit I've been told by someone recently that Pani's European lineup for 2012 is in fact capable of reproducing both 8- and true 10-bit video in "Prof" mode. My understanding is that any manufacturer that had implemented such a feature into their consumer TV lineup should be bolsting about it from any corner, unlike Panasonic.
Thanks everyone!
Edited by code681 - 3/19/13 at 9:09am
post #11183 of 12310
I fired up the vt50 last night and since the box looked like it had been open, I checked the hours. It said 48. Now I can't remember if that was minutes or hours, and I put the tv back in the box until I get the mount.
Does the service menu show minutes, or just hours?
[EDIT]
This post says it shows hours and minutes. Can anyone confirm?
http://www.avsforum.com/t/1408338/official-panasonic-vt50-owners-thread/6720#post_22399533
1. Enter Service Menu (Hold Vol. - down on the TV while pressing the INFO button on the remote 3 times).
2. Press the {2} button on the remote 1 time, to go to SRV-TOOL.
3. Press the {OK} button. A blue grid will appear with the following information.
TD2Mictocode: 81c00011
Flash ROM: 1-227E
PTCT :00.00.00.00.00
4. Cursor down to the PTCT :00.00.00.00.00 line and then cursor over to the right to highlight the empty box.
5. Press and hold the {MUTE} button on the remote for 3 seconds.
The TIME / COUNT info will be displayed in Hours and Minutes of Operation.
6. To exit, press and hold the {POWER} button on the TV for 2 seconds.
The display will re-start by itself.
Edited by M3 Pete - 3/19/13 at 11:09am
post #11184 of 12310
How do you check hours?
post #11185 of 12310
Yes. Phone and tv are directly thru my wifi at home. Do I have to search for Bluetooth items via TV? It keeps picking up my iPad.
post #11186 of 12310
Everything else on the viera remote works fine. Just can't figure out the keyboard.
post #11187 of 12310
CAUTION - don't screw around in the service menu unless you know what you are doing. Do what you need to and get out.
post #11188 of 12310
Interesting conclusion to my TV dilema. First thanks to everybody that pitched in trying to help me problem solve the issue. Just one of the reasons this forum is such a valuable resource. I have another thread going in the Marantz forum about my pre which isn't outputting sound. While on a tech support call with Marantz i brought up the TV issue an asked if the sound portion of the pre is screwed up could it also be messing up the picture, he said it could be and suggesting going source directly into the TV to find out. Obvious, but didn't occur to me. So i plugged my blu-ray player directly into the TV and viola perfect picture. So thankfully i'm only dealing with a defective pre. Since it's last years model i have to choose between trading for a open box or upgrading to the current model for more cash. Blah decisions! And again, thank you!
post #11189 of 12310
Doesn't work on mine! Is this guide for VT50-series?
post #11190 of 12310
It definitely works. It may different on the EU models?
