AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic VT50 owners thread
Official Panasonic VT50 owners thread - Page 24
post #691 of 12287
96 hours down 4 hours to go on the slides! I'm watching movies all day on my 65" VT50
post #692 of 12287
I'm getting a 65 incher for my man cave, it's a very dark room. How do you guys find the 3d? Is it bright enough?Crosstalk?
post #693 of 12287
Nobody seems to be talking about this. I'm curious about the 3D as well...
post #694 of 12287
I think u meant> after the final 4 hours of slides, then you'll me watching movies thereafter all day/night long........
post #695 of 12287
Don't have one (yet!), but it should be plenty bright in a very dark room.
post #696 of 12287
Originally Posted by Bob539 View Post
Anyone else having issue with Samsung bluray player. It could be I don't have avr that supports arc but (3806 Denon) avr kept fighting with bluray player. I would hit Samsung than tv would go to input 1 (not arc) then hit hdmi 2 and bluray would pause. I would have to restart bluray. I moved hdmi to input 1 (non arc) and everything is fine. The tv just kept switching inputs and I kept switching back. Very weird
None of that has anything to do with ARC, Audio Return Channel.
Maybe you mean HDMI-CEC?
post #697 of 12287
Originally Posted by jcavila View Post
I have an 58" Panny as well on a monoprice mount. Won't the new 65" fit the same mount? I thought the VESA mount on back was the same. The 65" is actually lighter than the 58" V10 model. So I'm assuming that I should not need a new mount?
I hung the 58" elsewhere and am buying the same mount for my 65". I don't see why it wouldn't work. Just buy shorter screws if you plan on slamming it up against the wall...I picked up some M8x1.25 16mm bolts for the back of the TV, which should bring it to about .75" away from the wall.
post #698 of 12287
Your right
post #699 of 12287
Seemed plenty bright enough to me can't really speak to crosstalk as I have no experience with other displays in 3d.
post #700 of 12287
No one cares about 3D..
post #701 of 12287
I got my 65" yesterday! I love the THX bright room setting but I noticed that the pixel orbiter is off in the THX settings and grayed out. I watch a lot of ESPN and play video games which makes me concerned with this option being turned off. Am I right in being concerned or is there no worry of IR?
post #702 of 12287
Change the aspect in the settings to size 1 and this will enable the orbiter.
post #703 of 12287
Really? Wow thanks a lot I'll try that when I get home.
post #704 of 12287
You know after I posted that I realized that's probably what your doing. I'm moving my 58" to the bedroom but will be using the stand so I will be using my current mount. I have it hung above the fireplace. I have mine angled down slightly so I've got room. Now if my TV would just get here all will be well in the universe. lol I should hopefully be getting in a week.
post #705 of 12287
Most universal mounts fit most units.......
post #706 of 12287
So far awesome!!!!!! 55VT50 looks beautiful. Took a pic but its a crappy pic
Attachment 246369
Will take more pics as i test. Having issues with fios
post #707 of 12287
Received my 55" VT50 yesterday.
This is after first trying out a PN51E8000, and than a 50" GT50.
Extremely satisfied with what I have seen so far from the VT50, this one is a keeper.
The black levels are absolutely amazing.
I will admit my knowledge is limited when it comes to high ends TV's right now and I have been taking the time to better understand what they can do/offer.
One of the reasons I went with the VT50 is after reading about it having 96hz playback.
I have a question if someone can help. In the settings menu for 24p playback the only options I see are 48 and 60 - is 96hz something that is just on by default when it is available?
Thank you for any information, much appreciated.
post #708 of 12287
LOL your crazy Nick
post #709 of 12287
The option will pop up when you feed the TV a 24p signal.
post #710 of 12287
Originally Posted by jest79 View Post
Does your Vt50 buzz as much as your samsung pne8000 because I plan to do the same thing
I don't have it yet.
post #711 of 12287
Thanks for the reply.
Blu-ray is a 24p signal, correct? While watching one the option was not available. Or maybe it was that particular blu-ray I was watching? Or maybe I have to be in custom mode?
post #712 of 12287
Could (possibly) have been the blu-ray (some Blu-Ray TV shows are 60), but it's more likely your Blu-Ray player isn't set to output 24p. There should be an option somewhere in the menu. You do not have to be in custom mode.
post #713 of 12287
Good talk.
I do, so I'm sure there are a few others out there that do as well.
post #714 of 12287
ok thank you, I will check out the settings on my blu-ray player just incase.
I have only watched Tron 3D and some episodes or Rome (HBO) on Blu-ray so far.
I recently picked up a BDT-320 - not disappointed.
post #715 of 12287
This past April I started buying a new Plasma, and the PN51E8000 was the first of 3 TV's I tried.
Out of the 3, the E8000 easily had the loudest constant buzz.
the GT50 50" only had a slight buzz on bright scenes.
the VT50 55" (keeping this one) has an even slighter buzz on bright scenes - but I do seem to notice a very quiet constant 'hum' from maybe the power supply. I expect that from a TV this large though.
post #716 of 12287
Please everyone visit the custom VT50 settings thread and share your settings
http://www.avsforum.com/avs-vb/showthread.php?t=1410156
post #717 of 12287
3D from what I have seen so far is impressive and while I did notice occasional cross-talk - it was very rare.
So far I watched Tron 3D, and half of Resident Evil Afterlife 3D.
If I were to compare Resident Evil against the GT50 50" I was recently using before the VT50 55" - there is even less ghosting and cross-talk. Overall depth and pop out were about equal.
3D is something I have grown to love.
post #718 of 12287
The 65" VT50 is incredible!! The picture looks fantastic and it's not even calibrated yet. I don't see any green blobs or banding issues. Much better than the VT30 in my opinion. I'm very happy with the TV so far.
post #719 of 12287
Just order my 65vt50 in canada 3700.00 was the best price i got .should have it in a week they said.
post #720 of 12287
I picked up my VT50 a few days ago, and have had a chance now to mess around with it, and test out my Blu-ray movies. I've been checking out Baraka with it, and it just looks stunning. Especially in THX Cinema mode.
