Originally Posted by AndrewXUK
I have my P65VT50 om top of a cabinet using the standard pedestal. The cabinet has an open 3 shelf center section - shelves just fit standard component width - may 18" wide. I want to add either a 5.1 speaker set-up (preferred) or a sound bar. The problem is there isn't a lot of room between the cabinet top and the screen to fit a center speaker or bar, especially as it would obscure the IR and C.A.T.S sensors.
My options seem to be:
a small center speaker in the cabinet,
a low center speaker in front of the TV
a low sound bar also in front of the TV.
Has anyone else dealt with this issue and what set up have you used?
I have purchased the following which has been incredible for me...
http://www.thesimpletvstandstore.com/p-6824-salamander-designs-synergy-pm300xlk-expansion-kit-increases-max-mounting-screw-spacing-to-38-w-and-2125-h.aspx
I could not wall mount my 55vt50 due to the fact that I live in an apartment. Also, the walls just weren't suitable for hanging this size TV. I then ran into the same problem regarding the position of my center speaker. I ended up getting the salamander mounting kit I listed. This allowed me to lift the TV up for better viewing as well as fit a nice Polk Audio center speaker on my TV stand which remains under the TV. It was a sizable investment, but it looks great and doesn't damage your walls.
![Wow: World of Wonder [Blu-ray]](http://cdn.avsforum.com/1/11/50x50px-ZC-1166fb14_B00462PTDQ-51E0ByQYHsL.jpeg)
I had purchased the TV after we had all the furniture and moved in. But I if you don't already own a nice TV stand, I would do as you recommend and purchase a new unit that fits everything.
