AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic VT50 owners thread
Official Panasonic VT50 owners thread - Page 308
post #9211 of 12304
Originally Posted by billmich View Post
Quick viera link dnla question( which I know everyone here says is a bad interface)
Sending pictures to my TV via my iPhone, I can rotate the pictures around using my remote
Videos I send always seem to be sideways with no way to adjust (that I know of)
Any help here
Or does anyone know how to edit a video in my iPhone an rotate and then I save it so it correct
Thanks in advance
Bill
Any help on this?
post #9212 of 12304
I just got the 65" VT50 last week and ran the 100 hour break-in slides. After getting everything setup for the first time last night I tried out some blu-rays and noticed there was a slight lag between the audio and video. This is for 2D content (haven't tried 3D and probably won't). The audio was just slightly ahead of the video. I'm replacing a 2006 Samsung DLP and never noticed this audio/video difference. The TV is the only new thing in the setup. My setup is as follows:
Oppo BDP-103 HDMI 1 output to Panasonic 65VT50 HDMI 1 Input for video
Oppo BDP-103 HDMI 2 output to Pioneer VSX-1017TXV-K receiver for audio
Has anyone else experienced anything like this or know what settings might cause this? It's just enough difference to be annoying. I'll have to try it with broadcast TV some more to see if I notice it, but in the little that I watched I can't say I noticed it. With the video output from the blu-ray player going straight to the TV I'm surprised the video is lagging behind the audio. Like I said, I never noticed this problem with my old TV and I was using the same wiring setup.
post #9213 of 12304
About the input lag (or lipsynch). I know if you disable all the motion processing and use 1080p direct input the input lag is non-existent (or not distinguishable). However, if you do enjoy having the motion smoother on etc you'll have to use your AVR's lipsynch feature or set the audio delay manually to synch the sound up.
edit: failed to explain, the lag you noticed is due to all the video processing that these new tv's do. When sound goes direct to them they account for the synch issues internally, but when you split sound and video like you and the rest of us you have to use the AVR features to synch it or disable as much processing on the tv side as possible to mitigate the lag.
post #9214 of 12304
Any help on this?
Bill, i think you'd be better served asking this question on a board that deals with iPhone issues. Not trying to dump on you, but you'll have a larger pool of people that can help with this iPhone specific question. Best of luck.
post #9215 of 12304
Was more asking if there is anything that can be done within the TV,
I actually downloaded a n app that can rotate video, but even after saving in all 4 orientations, the one orientation I was looking for didnt work..lol
No offense taken, and thank you for taking the time....
post #9216 of 12304
Thank you for the reply. I'll look into setting an audio delay in the receiver. I thought I tried it without the motion smoothing stuff on and it was still apparent, but I'll try it again. I'm not a huge fan of the motion smoothing, but set to low it makes some things nicer. I also had the 1080p direct input turned on too as you suggested. I'm very excited about watching movies on this great TV (already input some ISF settings using ControlCAL), so if I can get the audio synced up it would be perfect.
post #9217 of 12304
Is this a setting on the VT50?
B
post #9218 of 12304
I believe he is talking about the "1080 Pure Direct."
post #9219 of 12304
What is that....? Is that just built in or some kind of setting? I haven't heard of that. Just asking because my receiver has a pure/direct mode.
post #9220 of 12304
Is their anybody out in the San Diego area know a reputable calibrator?
post #9221 of 12304
Hi Mac13 - I was talking about the pure direct mode available in the advanced picture settings of your VT50. You will only beable to enable it when a 1080p signal is incoming. One of the things it does is bypass some processing in the tv, but I recommend you read the following link for more info on it: http://www.hdtvtest.co.uk/news/panasonic-tx-p50vt50b-p50vt50-201204101757.htm?page=Performance
enjoy
post #9222 of 12304
enjoy
Thanks for the info!
post #9223 of 12304
Originally Posted by Styphin View Post
Hi Emclean,
Well, I bought the exact same setup, 65VT50 and Elite SC-61. Like you, I'm pretty newb, but learning stuff everyday by lurking around the forums here. The TV is currently breaking in using D-Nice's slides from the HDJ's forum. I ran a few minutes of Toy Story 3 on my set before starting the breakin and it looked freakin amazing, and I haven't even started playing with the picture settings yet. Also, I've heard nothing but good things about the SC-61, EXCEPT that setup can be difficult, UNLESS you have the iPad or iPhone app, which makes it very easy. My SC-61 is supposed to get here tomorrow so I haven't had a chance to use it yet, but I did tons of research and felt the SC-61 was the best receiver for my needs.
So did you buy a good setup? My answer would be yes, that is a very good setup.
2) I've read a bunch of stuff about breakin, and consensus seems to be 100 to 200 hours. Some folks run slides for 100 hours then mixed content (no channels with logos!) for another 100. I've read that Panasonic states that severe image retention or burn-in can be an issue up to the first 2000 hours (yes, THOUSAND), but don't let that deter you from watching your TV. Just don't leave it on a static image overnight and you should be fine.
For me, I'm just gonna run the slides for 100 hours straight (yes, I'm running them overnight, so 4 days total. You don't have to run it overnight, but it's obviously quicker. You're not doing any damage to the TV; just make sure the slideshow is playing and not paused so it goes to Viera's screen saver mode) and then I'll baby the TV for another 100 hours with Blu-Rays and HD movie channels (so no video games for a while.) Then I'll run the AVSHD 709 calibration disc on my set (google AVSHD 709 and you'll find it, it's free to download, which you can then burn on a blu-ray or DVD). If I'm not happy with those settings, then I'll look into buying calibration software, but we'll see how the AVSHD disc does.
Word of advice, when running the slides, check for cracks or dead pixels, but don't overly inspect the screen or you'll start swearing you see inconsistencies and patterns in the grey and white slides. Note that plasmas, in general, do not provide completely uniform whites, and from what I can tell on the VT50, it's no different. However, typically it's a minor thing that you will probably never notice except on these slides.
3) I got the Squaretrade warranty off of Amazon and it looks pretty legit. Good reviews. Seems to be good coverage. I feel comfortable with these warranties. Square Trade will send out a tech to your house to inspect the TV, so you don't have to ship it unless it has to be replaced.
Buying a warranty is like gambling. Spend $300 now (I spent $400), or maybe end up buying a new set a year from now. Or maybe not! This is a decision you'll have to make on your own. The VT50s are well built sets but things do break, and I've read forums with several people having issues with their set.
Let me know how your setup goes. Since our systems match it will be very good to know someone out there has the same setup for any technical issues.
-Aj
Originally Posted by laulau View Post
Recommend getting the SquareTrade warranty from Costco online. 3 extra years for $99.99. You can purchase the extended warranty even if you didn't buy the TV from Costco. Reportedly you don't even have to be a Costco member but it will cost you $5 dollars more...haven't verified this as I'm already a member.
Originally Posted by jadziedzic View Post
I went with a Peerless ST670P tilting wall mount; it has a fairly wide mounting plate that will easily span 3 studs even if the middle stud is off center by 8 inches or so. I used the non-tilting version of this mount for a Samsung 46-inch LCD I bought for the exercise room. I know Monoprice is usually about one-fourth the cost of the "name" brands, but I felt an extra $50 for a $2500 television wasn't too unreasonable, and I had prior experience with the Peerless model. Of course, I'm still waiting for my set to be delivered, so take my recommendation with a grain (or two) of salt! smile.gif
Originally Posted by ViciousLord View Post
This is what I used. I weigh 215 lbs. and I was hanging off the edge of the mount after mounting my 65" weighs about 140 lbs. The back plate spans the width of my old LG 50". I think you'll be fine.
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082801&p_id=6663&seq=1&format=2
Save the extra cash and buy a 3D Blu-Ray movie or two.
Thank you for the responses and advice everyone. I've got my mounts narrowed down to a few options. I think just for peace of mind I'll pull the trigger on one of the Costco $105 (non-member price) Squaretrade warranties. That is an insane price and I can totally justify that. The $500 or $600 BB warranty the guy tried to sell me was 100% out of the question! So I've had the tv for 6 days now. The first couple of days I wasn't able to do much with it because I was setting up everything else: my receiver, bridge modem, re-programming remotes, moving my old Onkyo 807 receiver to my bedroom, etc. I let one of my roommates watch the Dark Knight Rises on it once I got the Elite SC-61 hooked up and calibrated. Man I had no idea my speakers could sound that good. All in all, there's probably been only around 4 hours of programming watched so far. This past Saturday I started the break-in process using D-Nice's slides. They've been running day and night since Saturday morning. Is this bad? Should i cut the TV off for a couple of hours and then fire it back up later? I haven't noticed any dead pixels or any buzzing sounds so far so I'm keeping my fingers crossed mine won't start. I've probably got close to 60 hours on it now. Geek Squad is coming out on 1/26 to do the calibration. How many hours should I try to have on it when they come? I'm going to run the slides until Wednesday after work. That'll be around 100ish hours (considering if i need to take a break and cut the TV off for a few hours). Will that be good enough to calibrate or should i run the slides longer? Thank you!
Edited by Emclean07 - 1/14/13 at 12:35pm
post #9224 of 12304
Hi,
Check out Jeff Meier (umr on AVS), D-Nice here on AVS (both may tour there) and Bill @ Coast Calibration.
post #9225 of 12304
Has anyone personally had any experience with Geek Squad calibrating their 65VT50? I've read stuff bashing BB techs saying they are inexperienced and to stay away from them. I've also read some good stuff. But I also can't seem to really find many posts from people who have actually had the calibration service from BB themselves though. All I've found is people saying my brother's girlfriend's dad used them or my neighbor, but no personal experiences. This could also be my sign to stay away because I CAN'T really find anything. But anyways, I have a Geek Squad appointment next Saturday, 1/26 to calibrate my VT50. Since it is free I figured why not. I would love to get an independent expert to come out but I don't really have that in the budget right now. I am very inexperienced when it comes to TV calibrations but now I'm a little scared Geek Squad might mess it up. Should I adjust the settings to what D-Nice and others have suggested and just call it a day? Or adjust to D-Nice's settings and then let Geek Squad tinker with it also? I'm really torn on this.....
Thank you!
Edited by Emclean07 - 1/14/13 at 1:53pm
post #9226 of 12304
Thank you!
Ya I am able to get a free one from Best Buy as well and am contemplating getting it done. Most people on here say to stay away but honestly I don't see what it can hurt as long as they don't go into the service menu. If they stay in the user menu then you can always just reset it if you are unhappy with the results. I will probably end up having them come out for the heck of it since it is free. Please let us (pm me please smile.gif )know if you go through with it and how it turns out!
post #9227 of 12304
Thank you!
post #9228 of 12304
I'm expecting my 55vt50 from Paul's TV to be delivered tomorrow. What build dates are you guys seeing from them? I'm hoping for a late one!
post #9229 of 12304
Got mine last Wed from pauls, have a Dec 2012 build date. No problems, no buzzing, IR.
post #9230 of 12304
Same here, got mine from Paul's TV yesterday, Dec 2012 as well.
post #9231 of 12304
Got mine a little over a week ago but not from Paul's, its a November build. As long as you get an October or later build you shouldn't have the issues with buzzing. Can't hear mine at all unless I stick my head behind the tv and even then its a very faint noise of fans or a buzz during bright screens.
post #9232 of 12304
Originally Posted by KONICA TECH View Post
D-Nice's settings! Where are these for the 65VT50:confused:
Not posted yet. Seems to be some question as to whether he will post because of the new 2013 models being released soon.
post #9233 of 12304
Thank you Thunderduck, I must have been looking at something else, my apologies! With no D-Nice settings that brings me back around to my quandary: Geek Squad or no Geek Squad?
post #9234 of 12304
You have a flagship tv hire a "flagship" calibrator, that would not be Geek Squad imo. I see your cal is free, I would pray they don't make your set worse, yes I have had a "bad" GS experience and a "real" calibration experience, no comparison imo
Edited by chunon - 1/14/13 at 4:20pm
post #9235 of 12304
It'll probably be a hit or miss with a BB calibration, personally I wouldn't pay for it. If you decide to get it done by a pro I'd at lest wait until you have 200hrs or more on it.
post #9236 of 12304
Originally Posted by LBJ2 View Post
Jim: the VT50 does carry 5.1 over HDMI with other streaming apps like Netflix and Vudu where available or indicated in the title of the movie. (e.g., not all movies are 5.1 in the Netflix Library). Unfortunately Amazon's Instant Video app specifically for Panasonic does not yet include 5.1/Dolby Digital audio. I had the same frustration with the Netflix app on my Sony BDP-S780 blu ray player--in that case I could get 5.1 from Amazon titles but not Netflix rolleyes.gif
In either case my Receiver is able to process 2.1 PCM input to 5.1 output on my speaker system.
Do you have to turn that on somehow in your receiver settings? I'm only getting 2.1 out of my front towers [and sub] and it is driving me nuts!
post #9237 of 12304
Chunon / 7thSeal,
That's what I was afraid of and thank you for the honesty! I really need a pro to do it but that won't happen for a while. I didn't account for the professional calibration in my tv and receiver budget. I've got to think though, GS would be able to do a better job than I could. If he messes it up I guess I can raise cane at the store and try and get someone to fix it or just return the TV. I've still got a week and a half until my appointment to decide what I'll do. I'll look around for pros in the Atlanta area and price some out. In the mean time, I'll continue to run the slides day and night until I hit 200 hours. Thanks again!
post #9238 of 12304
you are probably better off loading some of the settings in the other forum. Those will help you get through the first few hundred hours and improve the quality from the out of the box modes. or you can use THX Cinema and bright room also if you desire.
I would suggest saving for a professional to do it that is certified then playing the lottery at BB. If you can get the magnolia guys to do it and not the geek squad then perhaps that is a better option.
post #9239 of 12304
I will agree with using the posted settings. People say how good the THX modes are, but they pale in comparison to using some of the Custom settings found here! You might even get better results than the GS since they most likely wont do anything with the CMS.
post #9240 of 12304
I had Geek Squad calibrate my 65 VT50 on 1/11/13 Oct 2012 build date with 250 hours on it using varied content with no IR visible, Geek Squad-1_11_2013-L.Shaver.pdf 1031k .pdf file attached are the results. I used Toppers setting for my custom mode and that is what the compassion is off of. I think the colors are more accurate after the calibration but it seems a little dark. He did ISF day and night but that was it, no 3D. He only did 30 and 80 gray scale not the 10 point. I have already emailed those settings to Dave Evans at 21 Century Calibration for an evaluation and to schedule a recalibration if he thinks its warranted.
