I've been using my 08 HP laptop running Vista as a very modest htpc with a USB Hauppauge 950-Q that actually supports NTSC Analog Cable, Over the Air TV, ATSC Digital Over the Air HDTV and Clear QAM Digital Cable TV.
But for some reason WMC can't merge them all, I'm being forced to choose only one wich is very annoying!
Is there any alternative to WMC for Vista that will actually let me watch and record my over the air Analog/Digital and basic cable channels?
Thanks in advance!!
Thanks in advance!!
)...as you found out that within WMC you can only assign each tuner to one type of connection.
