Hello, I am in the process of purchasing and mounting a new Panasonic 60ST50 plasma over my fireplace and I am trying to figure out the best way to go about getting audio set up in the room. I know, I know, mounting the TV above the fireplace is not ideal but is the way it is.
I have attached a picture of the front of the room. I will be lowering the mantel height by about 3-4" to try to bring it down a little closer to eye level. I have also included a little diagram (not to scale) on how the room will be set up. Any help with speakers and speaker placement would be awesome.
I currently have a Klipsch surround sound set up (all large, floor, center, sub and rears). In light of the wifes request to minimize large speakers I have tried to do all kinds of research to find decent speakers (either in wall or small book shelfs) without spending a ton of money or sacrificing sound to an extent.
Upon researching I came across the in wall speakers offered by Monoprice, these are significantly cheaper than anything else and seem to have decent reviews. I'm not sure if anybody here has any opinions on these speakers and/or which ones I should consider. I am also considering keeping my sub/center speaker and picking up four Klipsch R-2650-W's... I can't seem to find any reviews (customer or professional) on these speakers so I guess I would be buying on gut feeling and past experience with Klipsch.
As far as mounting goes, I was planning on mounting the left and right speakers so that the bottom of the speaker matches up with the bottom of the TV, the center would either go centered in the wall under the TV or on the mantel if I kept an in box speaker. The rears I was going to try to put up about 7' and try to center them on the side walls where the "primary" listening area would be.
Any help/advice or even telling me that I am crazy would be sufficient!
Thanks in advance for any help, and as the construction ensues I will make sure to post updates and pictures.
PS I will be running these speakers with a Yamaha RX-N600
Shleybells
Shleybells
Living room.pdf 30.4541015625k . file
