Last week I bought an autocal package that Spectracal put together for me that consisted of Calman v4, a C6 meter, and a Lumagen Mini3D. I am using it with the following system:
Panasonic AR-100U projector
Onkyo NT 808 receiver (hdmi switcher)
50 foot HDMI cable
03112012 firmware for Mini3D (latest)
Everything works fine (without calibration) with the Mini3D out of the loop. When I try to autocal with the Mini3D the gamma and greyscale seem to calibrate correctly. But when it goes to do the color gamut all hell breaks loose. The Mini3D will put up the correct test pattern for a color or two. Then all the sudden say it is suppose to be working on blue, the Mini3D will be putting up a red pattern! I have seen a case where it was suppose to be working on green and put up a blue pattern which of course messes things up.
For further info I got into the menu system of the Mini and the "Reference" color patters were fine but when I looked at the "Adjustable" color pattern for blue it showed red there too.
One last problem. When all of this happens the Mini will go into an output mode that looks like a negative from the old days of film photography. Changing from RGB to Yxxxxx etc does not fix it; only a factory reset will put it back to working properly..... that is until I try to calibrate color gamut again.
I have contacted both SpectraCal and Lumagen but wanted to see if I could get some ideas for a solution here.
Thanks for any help with this problem you can provide.
50 foot HDMI cable
