As I mentioned in the projector forum, I've picked up a used Panamorph UH480 Anamorphic Lens, from another AVSforum member, and I'm all giddy. So I thought I'd share...and ask some questions.
As a dedicated "zoomer," why did I buy one?
As some here know, my system was deliberately designed as a Variable Image Size system, to use the projector's zoom with 4-way masking to vary the image size to my desire. I had bought the largest possible screen for my wall - larger even than could be accommodated by the throw distance (maximum zoomed out image size) of many projectors. And my throw distance is limited, so any projector ends up being placed within an inch or so of the back wall (actually, it's a bay window). So the mere depth/length measurement of a projector can add or subtract from my maximum image size. I have up to 124 or 125" or so available screen width, with my side masking fully retracted, that I want to be able to take advantage of.
My first Panasonic AE900 projector, being small, gave me the largest image size. My next, the JVC RS20 still gave a pretty big scope image, but not as wide. Now my new JVC RS55 projector, being even deeper, has limited the size of my 2:35:1 images even more. I was down to between 118" and 116" wide for scope. Only an A-lens would allow me to re-size scope images larger, in my room. And, I'm not one of those who is terribly worried and an A-lens affecting the image quality adversely (by putting more glass in the way) - every A-lens set up I've seen always struck me as looking great.
So, from the beginning, I designed my projector lift area to accommodate an anamorphic lens at some point. However, holding me back was the fact they are so darned expensive. Further holding me back is the fact I'm so happy zooming the image, including for scope, and it's not like I had a small image. An A-lens just gets me a few inches more, so it would have been hard to justify spending thousands of dollars on an A-lens given I don't use a strict CIH system, and that it would only be for those times when I wanted the widest image possible. But...a great deal I couldn't refuse came up so now it made sense and here I am. And, I know those last inches can really add impact - with an A-lens I'm back to about a 124" wide scope image again.
I'm at about a 1.8 throw ratio with the 16x9 image size, so I am told I can expect a bit of pincushion.
Pictures, and then first impressions and questions to follow...
