So, the two top contenders for my purchase (TONIGHT!) are VT30 2011 model or a ST50 2012 model...
I've done my searching and lots of recommendations to get the ST vs. the VT...I noticed the VT is 52lbs (!) heavier than the ST... Does the ST not have a glass front? Thats about all I can think that would make up that much weight...
It's hard to compare specs between these two models as Panasonic seems to have blanked out the specs on their comparison tool.. I noticed the ST has additional gradation levels (2x)... Are there things on the VT that I might be yearning for if I go with the ST? It'd be in a basement where the light levels are generally low (if lights are out) and would be used for movies and gaming primarily. Viewing distance is about 12 feet.
Is there much difference in black levels between these two sets? ie: I think the VT30 vs. GT30/ST30 had better black levels, were those just carried over to the new ST models and hence would be essentially the same?
Such a hard decision here..
Any input anyone can provide would be appreciated...
Oh and one other plus on the ST for me is the support for MKV (and other) files but I could just use an external blu-ray player for that so it's not a deal-breaker, image quality is more important since it'll be more of a monitor than anything...
Thanks for your input, please go easy on me, I'm a nervous wreck right now pulling my hair out....
Any input anyone can provide would be appreciated...Oh and one other plus on the ST for me is the support for MKV (and other) files but I could just use an external blu-ray player for that so it's not a deal-breaker, image quality is more important since it'll be more of a monitor than anything...
