AVS › AVS Forum › Display Devices › Rear Projection Units › Hdmi to component video cables ?
post #1 of 3
Hello folks I just got Direct tv for my home and the big screen that I have in the bedroom only accept Component video not HDMI my Direct tv satellite box only outputs HDMI I have and older style Mitsubishi HD tv it shows a great pic in HD I previously had ATT Uverse which used component video outputs. I have checked EBAY and it shows a HDMI cables with component cables on the other end of it is this what I use to make this conversion work ??
http://www.ebay.com/itm/5Ft-HDMI-Mal...#ht_2716wt_932
Thanks for the help !!!
post #2 of 3
previous threads stated that doesn't work. Check Amazon for HDMI to component converter ~60 to 100 $.
HDMI is a digital signal and component is analog. Conversion requires an active (powered) device.
post #3 of 3
Thank you so much !!!!
  Back to Forum: Rear Projection Units
