I recently purchased a pair of B&W CM8's as my front L/R to replace a set of Vienna Acoustics Haydn's. I got the B&Ws at Magnolia. When I was trying them out they were trying to demonstrate the bi-wire difference, with and without. I could tell the difference between these CM8's and the other speakers they have there, including the cheaper B&Ws but I could not tell any difference with bi-wiring.
I have since researched bi-wiring and can't believe it is believed to improve sound. It does double the gauge thickness which could make a difference if using crappy wire. But it is the SAME wire connecting to the two sets of posts on speaker since the other ends are connected together on the AMP, it is basically the same thing as taking one speaker wire and connecting the amp in the middle of it with the two ends connected to the speaker. I can appreciate that people may believe they hear a difference but I am at a loss as to any scientific explanation. I have yet to find any link that goes into the science of it with any kind of analysis. Does anyone have any links they can share? I am not looking for "opinions" that it works, I want to see formulas, graphs, spectral analysis, whatever, that demonstrates some benefit, at least on paper.
Setup
Marantz AV7005
B&K Reference 7250
Onkyo 282
B&W Rosenut CM8 FL/FR
Vienna Acoustics Rosewood Maestro Center
Vienna Acoustics Rosewood Haydn SL/SR
Infinity ERS 310 in ceiling SBL/SBR
PS3
DirecTV Super DVR
AppleTV
Setup
Marantz AV7005
B&K Reference 7250
Onkyo 282
PS3
DirecTV Super DVR
AppleTV
