Originally Posted by Ross Ridge
Yah, while NTFS has been reversed engineered and there are open source implementations with varying levels of completeness, Microsoft has never publically documented how it works exactly. It's not entirely clear that commercial product can use NTFS without Microsoft's permission, and I don't think Microsoft is willing to licence NTFS except by licencing Windows in its entirety.
In other words, the only way you're likely to ever see an AV receiver supporting NTFS is if it uses Windows as its operating system.
Windows will licence exFAT, which solves the basic problems with FAT, and is intended to be used with flash drives and memory cards. So far though I don't think any AV receiver supports it.
Finally FAT works well enough for use with an AV receiver anyways. The software built in to Windows will refuse to format a FAT disk bigger than 30GB but the file system itself can support drives up to 2TB. You just need to use other software to format the disk, and it'll work fine with both Windows and your AV receiver. FAT doesn't support files bigger than 4G, but since AV receivers only support audio files, that shouldn't be a problem.
It would be nice if AV receviers had Type-A USB connectors on back and front though. There's no technical reason, in hardware or software, that they couldn't.
Good to know!
