I'm looking for a suitable subwoofer for my 2.1 setup (which will eventually be 5.1.), and any advice I can get from the Bass Division of AVS Nation would be greatly appreciated.
I just bought a used pair of Ascend Sierra-1's for the mains, and I have a Pioneer VSX 1121 receiver. While my system will spend most of the time being used for movies/gaming, I care more about the sound quality when playing music. We don't watch many movies with big sound effects (splosions!), and when we do, it's at rather modest volume levels (-20 to -15 db on the receiver). As for music, we listen to a wide variety (classical, alternative, electronic, some jazz), so I'd like a sub that can has good overall musical performance as its primary strength.
My living room is small (17 x 12 x 8.5 = 1734 cu. ft.) but is connected to our dining room (14 x 10 x 8.5 = 1190) via a wide archway (no doors). Counting both rooms, the total volume is 2924 cu ft.
Given the small size of the living room, I am looking for a sub with a small footprint - primarily due to placement limitations, but also because of aesthetics.
After reading numerous threads, it seems that something like the SVS SB-12 might fit the bill, though I'm wondering whether something else might work as well. I've been looking at the Hsu VTF 1 Mk2, the Epik Legend and the Emotiva X-Ref 10 as cheaper options, though I'm worried that the Epik might be too big (and not optimal for music?), and that the Hsu and Emo might not have enough punch. I would be open to adding a second sub down the road if I started with something small first.
Any other suggestions?
My budget isn't strict, but I would put the SVS at or near the top limit, so let's say ~ $450-650. I'd also be interested in hearing what used subs might be recommended at this price range that meet my particular needs.
