Originally Posted by
BladeRnR
Jeff would you mind terribly if you added "Thor" (Ice Giants battle) & "Iron Man 2" (Final battle) please.
Thanks mate
Blade
ABOUT THE COMPARISON
I can get Thor... I didn't see Iron Man 2. Thanks!
My cabling will be here Monday. Then I can set up and disconnect my ADA for a few weeks.
At first I'm going to run the CB III HD with my QSC DACs as I'm afraid of any SSP without DSP correction
. But when I get time next week, I'll defeat the QSCs for a couple movies and see how things sound with out any room correction and compare.
At this point, I am thinking June 9 for a shoot out for a couple of reasons.
1. I'm having UMR (Jeff Meier) coming to set up my PEQ on June 6. That's a big job and then I will retire my QSC DACs. That said, I will keep the QSC DSP-30 for my subs. I will run the THETA Sub out through my QSC for all tests!
2. I will have Jeff verify levels in the Theta (and ADA) so things are fully level matched prior to testing and have him recommend crossovers and slopes.
3. When I compare SSPs, I will compare the Theta against the ADA with PEQ engaged and with it disengaged. Engaging/disengaging is fast and simple via software. I believe you can do so in real time as well.
