Originally Posted by vagoverto
Hello,
I just got the lg 47LM7600 a month of weeks ago, the tv worked relatively fine, but had some resets and freezes, so today i decided to update the firmware, everything seems fine but there is a HUGE problem with it, the TruMotion doesn't turn off.
I've tried reseting, disconnecting and changing to different settings in the trumotion; doesn't work, i leave it off but i can still see it, the only mode that seems to turn it off is Gaming. I really don't know what to do, maybe you know a way to rollback the firmware or something, i saw someone posted a method to rollback by pressing 9 on the options menu but the tv only came with the magic remote, so i can't press 9 in the context that is needed. Thank you for any help.
Ps. Sorry for my bad english.
Hello,
Are you experiencing this when watching network shared videos? If so, the Trumotion setting needs to be adjusted within the application/player in the options menu. The smart features Trumotion is within the contents player options and not adjusted within the main menu Trumotion area. I lost my mind on this one until I stumbled upon it. If you are watching a video via the network player, pause it, arrow over to options, click it, select Vid. Settings and voila! Trumotion adjustments are ready to be adjusted. I believe it was set to "clear" by default which is fairly high for my taste. I all but gave up on the DLNA movie watching until I located this setting. Sincerely hope this helps, I was going crazy with it.
, improvements on save energy now in this option can be calibrate sensor sensibility for best results saving more o less energy and be dynamic, thing that dosen´t will happen before,before only was dynamic,3d was updated now have more deep on option maybe before was 20=22 now,and in my opinion the reception drop in some channels because the update, before the update,the reception in all channels was good even with poor signal,now less than 62% of signal is = only audio before wasnt like that,apart of this function don´t seems to be a big update maybe only minor bugs corrected, i hope a firmware version 4.x.x this update maybe come with trumotion option, or lg dosen't implement this opcion on true capable tvs because her mercantil ideology don´t let him
