AVS › AVS Forum › Video Components › Home Theater Computers › RAID 1 external enclosure for 10k RPM Velociraptor drives?
post #1 of 2
I'm looking for an external solution for a RAID 1. The enclosure must have embedded Hardware RAID.
Does anyone know of an inexpensive but FAST solution for this?
Needs to have USB hookup and also eSATA or something faster. Need both hookups for maximum flexibility.
I found this one, but can't find any reviews on it. So not sure if it sucks or is good?
http://www.newegg.com/Product/Produc...82E16816111209
post #2 of 2
USB is going to be kind of slow, especially with using 10k drives. It would be a huge bottleneck. What exactly are you using these drives for, and what kind of server are you using to pull the information off of them? Sans Digital is one of the more common units out there.
