Hi guys,
I have a pinnacle pctv 110i tuner card that has a 7 pin s-video in port. My local cable operator has a set top box that has 3 pin composite out (red,yellow and white wire).
I have successfully connected the 3 wires at the back of the stb and i am using an s-video to component adapter
The problem is i get only mono audio. The audio is only on my right speaker and the left speaker goes dumb. Also the video frame is limited to 320 by 240 but if i m not wrong it should be atleast 640x 480.
What am i doing wrong ? All settings in the stb and the computer software are correct. I hv tried using vlc , christv and a couple more programs but same result with all.
Attached below are the pics. I know this is not an ideal adapter but i get clean video and this is the only one i hv at the moment.
The adapter.
Back of the stb
Current connection(RED to red, WHITE to blue, YELLOW to green)
The adapter.
Back of the stb
