Hi, I think I'm having buyers remorse. I just purchased the i3-2100 to go along with an ASrock z77 and 8gb of G.Skill Ram. I will be using an existing Crucial M4 as the OS drive and run Win 7.
Before I ordered the i3 I was eyeing the i5-2500k. But after reading so many comments in there about overkill, i decided to save myself $100 and go with the i3. I'm sure it will handle any HTPC video just fine without a separate graphics card. My only concern is in the video rendering. I plan on ripping Bluray discs and converting them to MKV. I also plan on editing HD video by using Adobe Premiere.
I'm currently using an E6550 chip and it takes hours to render video or 20 minutes to unrar files. Realistically how much of a difference will this make i3 vs i5? Should I call up Newegg and cancel my order, and replace the i3 with the i5?
