AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › What makes one 12" sub > another 12" sub
post #1 of 2
Right now I'm looking at...
http://www.triadspeakers.com/products/irssub.html
At ~$1550 MSRP, what makes this better than say...
http://www.rythmikaudio.com/F12.html
...at $875.
How does a same size woofer vary so much in performance? I have all Triad speakers and have the mindset that the Silver Sub will perform better, and more "matched?" to my speakers.
post #2 of 2
Depends on the amp ,driver and box they need to compliment each other and some design theirs to play with more authority and depth over others without testing its hard to say.
Subs are not voice matched like the rest of your speakers so you can choose the brand you like.
