AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PS3 Slim wont accept disc. Also black screen after starting up downloaded games.
post #1 of 6
Hey everyone.
So I bought a dodgy PS3 which was fully working when this guy shown it to me but seems to had deteriorted since then, so I thought I'd have a go at fixing it myself. So first thing is the disc wont always be accepted, maybe once every 10 times it will work and will play the disk fine without any problems and will also eject. However if I turn off the PS3 then it will not eject on the next boot. Also if I put in a disk when the console is off, then it powers on. I think the sensor board is the culprit.
Also on games which I have downloaded the first time I play them they are fine and work flawlessly, however, if I reboot my console it doesn't work after that and I just get a black screen after pressing x to start up the game. But this isn't my main priority. Any advice would be great.
Cheers
Eddzzz
post #2 of 6
My advice: Back everything up and get a new one. if possible of course.
post #3 of 6
Yeah that would most definately be the easiest option but I just wanted to have a go at fixing it and want to see if anyone has fixed this problem before, as I'm sure theres a way. Cheers anyways
post #4 of 6
Happy to help! Hope you get it fixed somehow.
post #5 of 6
To try and fix the faulty gmae boots try booting into recovery mode and run the disk diags. Might be a bad HD.
post #6 of 6
I tried this already and run a check on the hard drive on my computer and all is fine. Will still try another HD though. Cheers
  Back to Forum: PlayStation Area
