AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Undecided upon
Undecided upon
post #1 of 8
I've been doing quite a bit a reading today and each of the following subs, and I think I got the gist of each model. The following models are
Hsu STF-2 $350
Energy VSW10 - $380 (WAF)
Energy S10.3 - $200
I just wanted to know if the Hsu STF-2 is worth the extra $150 compared to the S10.3
Also, is the VSW10 have a tighter sound at lower Hz compared to the STF-2, it states that I can hit lower frequency, but does it start to sound muddy on the VSW10?
I'm mainly looking for clarity over the rumbling of the room.
Room is 12Lx10Wx8H w/ an open side to the kitchen. 50% movies 30% music 20% games.
post #2 of 8
Your room "size" is going to include ALL of the space open to your room and any adjoining rooms/stairways/halls/etc. Measure and report back.
Bill C
post #3 of 8
12x22x8
post #4 of 8
The STF-2 and the S10.3 have 10" drivers and 200W amps, their cabinets are similarly sized, and they have similar extension numbers (STF-2: 25Hz @ -2dB; S10.3: 21Hz @ -3dB). The STF-2 may have higher output overall, but I can't confirm (or deny) that.
So, IMO, the STF-2 isn't worth $150 more than the S10.3. Given the size of your room, I'd just add another $50 to the pot and get dual S10.3s.
If you're at all able to stretch your budget to $499 (shipping included), the Outlaw LFM-1 Plus is a well-regarded sub worth considering.
post #5 of 8
My VSW10 sounds much tighter than my STF-2 did. I found the difference both unexpected and striking.
post #6 of 8
I took a look at the outlaw LFM-1 Plus a while ago, but the size of is a bit to big for my place. Stretching the budget to 500 isn't a problem, except for the fact that anything above or around $500 has a large cabinet. Thanks for the input.
Also, what do you mean by a higher output overall, I've seen this everywhere but I've always been unsure what it mean.
Anyone know if it's a good gamble to go with B-Stock w/ Vanns?
Awesome someone who has listen to both side by side. I was leaning toward the S10.3 due to the price factor or the VSW10 because of the WAF, it can be hidden so easily.
post #7 of 8
Perhaps I didn't use the correct terminology, but what I meant to say is that while both subs might play roughly the same range of frequencies, the STF-2 might play louder (have more output) than the S10.3 at most of the frequencies within that range (and, therefore, have "higher output overall").
post #8 of 8
Thanks for clearing it up, It makes a lot more sense now.
