Hi. I have a Dell U2311H 1080p/60hz monitor and I'm looking to purchase a surround sound speaker system to go with it. Going to my monitor, I currently have a Direct TV HD receiver (HR25-500), an Apple TV (3rd Gen), and a Macbook Pro laptop.
All of these devices have HDMI out and I would love to able to plug each of them into the surround sound system and then easily switch between each input via remote. I also want to make sure that I'm getting the highest quality available from each device (I'm a newb so I'm just assuming that this just consists of 1080p video and Dolby 5.1 audio).
I have found a working Samsung HW-C560S Home Theater System on craigslist and I'm pretty sure I can talk this guy down to $100. That seems like a good deal to me and I definitely don't see any other 5.1 surround sound systems with HDMI in that price range. I've read that there is no onboard HD decoding but I really don't understand what that would mean for me. I've also read that the subwoofer is passive so I guess I should look into buying a powered subwoofer as well.
So my question is, should this speaker system do everything I want it to or are there better options I should consider?
when I was still a kid in college, I didn't know much about quality audio (all I'd ever had were cheap shelf systems and boomboxes and things like that), so I bought a HTIB, and it satisfied me for a while--even Pro Logic was a revelation at the time, along with having a subwoofer. But when I started to look into larger rear-projection CRT TVs (a 32" direct-view CRT had been the gold standard of home theater for a long time), I noticed that their speakers--large and of relatively high quality for TVs--sounded noticeably better than the speakers of my HTIB system. At the time, that was frankly embarrassing.
That's when I started looking into hi-fi speakers, and realized that what I should have done was buy quality components from the beginning.
In such cases, the HW-C560S will use Dolby Pro Logic II to derive a 5.0 soundtrack (the subwoofer will still be active, even without a dedicated channel), which actually works pretty well, although it's still not true 5.1. How big of an issue this is depends on what content is available on iTunes and other sources you'll be using through Apple TV (I have no idea).
After all, we are just talking about spending $100 on a complete system that will be used with a computer and a small monitor, as opposed to a full-blown home theater. And it's better than what I use with my computer.
