AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Will BIC America F12 match well with my system?
post #1 of 20
I have the Bose Acoustimass 6 Series II System. I know, I know, everyone bashes Bose, But I got it a loooong time ago before I was more educated on Bose and everything. I got it in 1999 I believe. Please don't add on to the bashing, I get it, it's overpriced. I'm just trying to improve the bass at this point and I don't know anything about subs, so I just wanted to see if getting the BIC America F12 Powered Subwoofer would be a good match to my system which includes the aforementioned Bose Acoustimass 6 Series II system and a Onkyo TX-SR606 receiver.
Also, I wanted to know how I would go about hooking this up to my system. I am guessing I should leave the Bose Bass Module since all the speaker wiring goes through that before it's plugged into my receiver and I would use this BIC America F12 as an ADDITION to the bose module in my system and plug it into my Onkyo's Subwoofer input? But when looking at the back of the BIC sub, it looks like speaker wires need to be connected to it as well? How would I connect all this with my system correctly? (sorry for the newbie question)
Finally, is there a better option than the BIC America F12 to connect to my system that is the same price or less? ($188, Free Shipping, No Tax) ?
post #2 of 20
Going to say it before someone else does. Might be better to just to sell the Bose and use those funds on a better HTIB out there. But if you really want to use the F12 you could use a RCA cable from the SR606 to the sub. Regarding the Bass module...not sure how that works so someone with Bose experience will have to comment on that!
post #3 of 20
Quite often, if something requires a "special" hook up in order to make it function the end result isn't worth the hassle. Since you've had the system for 13 years it might be wiser to just upgrade the entire thing, in one shot. That would get you something far more current, while also enabling you to integrate it without any additional steps.
post #4 of 20
Well, I think it's different when it comes to speakers. Unlike other technology like computers, which get obsolete over time and need upgrading, I believe things like speakers can still give you good sound years or even decades later.
post #5 of 20
Regular White/Red RCA cables? or Digital Coax type cables? What would one need to buy to get maximum output from this Subwoofer?
post #6 of 20
A subwoofer cable - such as this one - connecting the AVR's subwoofer output to the sub's LFE input.
... I believe things like speakers can still give you good sound years or even decades later.
Good speakers, yes. Small cubes with 2.5", full-range Twiddler (TM) drivers, not so much. (IMO, and my comment is not intended as a flame.)
The cubes appear to have L+R terminals and, according to the manual, the system (and presumably each cube) is 4-8Ω compatible, so there's nothing stopping you from using them with your new AVR + sub. But you will likely have to set the crossover in your AVR quite high (140Hz? 160Hz? 180Hz?) and that may result in excessive "localization" of the sub.
There is definitely a benefit to be had from replacing those cubes with larger (bookshelf or tower), better-designed (two-way or three-way) speakers.
post #7 of 20
^^^ Very well stated. You told the OP the truth while being nice and not harsh........ I agree 100%.
post #8 of 20
So set it differently than what Audyssey automatically set up with my Onkyo 606? And how would you know which one -140Hz? 160Hz? 180Hz?
What do you mean by localization exactly?
post #9 of 20
I have this Sony Digital Coaxial Cable, is it something completely different or would it work?
post #10 of 20
No, sorry, by "you" I meant Audyssey, which should correctly determine the crossover setting. But if, for some reason, Audyssey were to set it at what seems like an unlikely low number (say, 100Hz), you would most likely want to raise it.
Too low a crossover for those speakers and you should notice a large chunk of audio spectrum missing, and perhaps also an imbalance between the speakers and sub (favouring the sub). Using the above example of an incorrectly set 100Hz crossover, I would employ a bit of trial-and-error and:
- raise the crossover several increments (say, up to 200Hz), listening to the results after each change;
- lower the crossover a few increments, listening to the results after each change; and
- settle on the crossover setting that provides the best overall sound + the best balance of audio between the speakers and sub.
Higher frequencies are directional - you can tell where they're emanating from. Lower frequencies are less directional. Below a certain point - usually 80Hz - it becomes difficult if not impossible to tell where frequencies are coming from.
The higher the crossover frequency, the more likely you'll be able to pinpoint where your sub is because the frequencies coming out of it will be directional. The lower the frequency, the more the sub "disappears" and all you end up hearing is the individual speakers supplemented by the lower frequencies "everywhere". With small cube speakers, you will have to set the crossover at a level significantly above 80Hz (my guess is somewhere between 140-180Hz), which means the sub is more likely to become "localizeable".
I have this Sony Digital Coaxial Cable ... would it work?
Yup, that should work just fine.
post #11 of 20
I'm about to run Audyssey on my Onkyo TX-SR606. Should the sub be at a certain volume level when running the test or should I leave at at zero?
And after the test is complete, Should I just leave everything as is, or attempt to tweak anything in regards to the sub?
And since I will have to have the Bose Module and this Sub together in my system, is it ok if they are placed right next to each other in the room? I'm even considering placing the module ontop of this Sub unless that's considered crazy?
post #12 of 20
I thought owners of the BIC F12 complained that it was a poorer performer when crossed over above 100hz or so?
post #13 of 20
In these Bose systems, the bass module is simply the system's woofers, combined into one speaker and placed in a separate box. It is not a subwoofer. Because it covers so much of the audible frequency range, it should be placed as close to front-and-center as is feasible, since it reproduces part of the range that in a normal system would be considered upper bass or even lower midrange.
The BIC is a subwoofer. How it sounds will be a product, in large part, of where it is placed in the room, and this is something that requires experimentation. Google the phrase "subwoofer crawl" for an example of the type of experimentation, and the reasons for it, that I'm referring to.
The sub could end up in one corner or another, or along a side or end wall, or somewhere else, if you're actually committed to achieving its best performance. So for best results don't worry about placement ahead of time, and don't assume there will be any relationship between its placement and that of the Bose box.
For the purposes of Audyssey, the entire Bose system, includng the bass module, is 5 channels of "small" speakers with no subwoofer. The BIC adds a sub to that.
post #14 of 20
So what volume should the sub be at when performing the audyssey test?
I was planning on putting the sub in an area of the room where it is right by a window. Will putting the sub there cause any problems as far as damaging the glass when it is on?
post #15 of 20
Whatever volume BIC says is unity gain. If they don't say, try 7.
It's possible to rattle your glass with a sub, or even make it break if it's loose enough, but the location of the sub would be only one possible cause (it could happen with the sub across the room if all the factors exist for it to happen at all). If the window rattles when operating the sub at normal levels, get it fixed.
post #16 of 20
Most people with the BIC F-12 find they have to lower the gain setting on the sub to 3 or even a bit below to get it within an acceptable range for Audyssey set-up.
post #17 of 20
Thanks. I dont think it says anything on the manual, so I guess I will leave it the volume at 7 when doing the Audyssey test.
Get it fixed? what do you mean?
post #18 of 20
Sorry for the newb question, but when you say lowering the gain setting on the sub to 3, do you mean the volume on the sub?
post #19 of 20
Yes
post #20 of 20
If other owners are getting good results with the sub set to 3, go with that.
If the window rattles, fix the window.
