Is this system dedicated/proprietary for only Paradigm subs? I did some reading up on this when I was considering purchasing an Anthem/Paradigm setup - sounds like it's a great system.
I am nearly ready to pull the trigger on a Velodyne SMS-1 bass management system, but the PBK system would be far less expensive, as it is basically a microphone and some software for your computer.
If it's proprietary to Paradigm subs, then it's a no go for me. But, if you can use it on any sub, has anyone compared this to the SMS-1 system?
