I have a Paradigm PS-1000. It is a one note sub.
I want a musical, articulate and accurate sub for mostly movies, but almost equally for music.
Budget is about $1000.00. I might be able to add a little more if necessary.
What do you suggest?
I watch movies on my system at about -20db or as loud as -15db.
I want a sub to match the rest of my system, as it was the place where I saved money to get better components and speakers etc.
Thanks to all of you for your help.
, and you should end up with C Note in your wallet.
