So I've read through the stickied posts and searched for others, but basically what I've been able to take away is that every brand rates their watts/channel differently, and unless it's HK you don't know what you're getting.
My question is - what kind of power rating should I be looking for in order to push a constant 100W to my 6ohm fronts (5.1 setup)? Is it possible to get an AVR that will do it for <$500?
I keep looking at receivers advertising 100W+/channel, but then it always turns out that's with 2 channels driven, and it drops to around 80W/channel with all driven.
Thanks for any help
Thanks for any help
