Originally Posted by SimDuch
ok for anynet ! as for my speakers setup, here you go: http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44
so you suggest to put those to small (well of course) but to 80hz no matter what Audissey setup gave me ?
many thanks sir
S.
many thanks sir
S.
No. The Energy speakers will likely get set higher to say 120Hz. Any setting > 80Hz should be left at that setting, otherwise if you lower it below what the AVR set it to, the speaker will not be EQ'd below that frequency.
Another problem, to Watch tv without the sound from the receiver (you know late night etc...) sometimes it works by just turning on the cable box and the tv, sometimes I have to power on the receiver, switch to cable/sat mode, then turn it off and then the sound will jump to my tv... weird no ? any clues ?
Cheers
S.
Cheers
S.
For the "HDMI Standby" feature to work correctly, the "HDMI Control" setting must be set to ON as well as setting the "Standby Source" to CBL/SAT. You also may need to cycle the AVR OFF/ON for it to take effect.
