AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How do I watch TV and listen to CD at the same time on Pioneer VSX-1121-K receiver?
post #1 of 5
My cable box only has 1 HDMI port.
Thank you
post #2 of 5
Run HDMI directly from cable box to TV and optical audio from cable box to receiver is only way I know.
post #3 of 5
Thank you
Connect the cable hdmi to input 4 labeled video. Connect the cd player to digital or analog (red/white) to input labeled video. Now get both sourses playing. Hit the receiver button on remote, then press signal sel button (#4). From there select the active audio to play with that video. Page 38 in manual.
post #4 of 5
Thank you, got it working!!!
post #5 of 5
Your welcome.
