AVS › AVS Forum › Video Components › Home Theater Computers › Second HTPC
Second HTPC
post #1 of 5
I'm picking up a second HTPC. I got a steal on eBay. My first is set up perfectly. Is there any easy way to transfer settings/programs to my second computer?
post #2 of 5
Probably can't transfer the programs to different hardware but settings and files is easy. You don't say which version of Windows, but there has been a 'Files and Settings Transfer Wizard' in every post 98 version. It's in the Control Panel.
post #3 of 5
It depends on what you mean by settings. For XBMC, you can transfer the entire folder inside appdata to your new pc.
post #4 of 5
Basically I like the setup I currently have and I want to duplicate it. WMC settings, mediabrowser things like that.
post #5 of 5
I'm running windows 7 if that matters.
