AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pre-pro HDMI out M/C LPCM
post #1 of 5
I am trying to find a pre-processor that can decode all the latest formats (TrueHD etc) and output Multi Channel PCM via HDMI. I cannot find any info from different manufactures for this specification.
I was hoping a member here has had experience with there Pre-pro and can offer some light on the subject.
I did try one processor, but there was only 2 channel audio PCM over HDMI out.
It is possible with the Oppo and my PC soundcard.
post #2 of 5
Why, and what are you trying to actually accomplish?
post #3 of 5
I have the Smyth A8 Realiser, it has a HDMI input which I would like to take advantage of. I am trying to keep the signal digital until it reaches the DAC, then Balanced XLR to the amp. The Realiser has 7.1 analogue inputs, but that would mean D/A > A/D > D/A.
Bluray/PC > Pre-pro > Realiser > DAC > Amp > Headphones
At the moment I have the PC connected directly to the Realiser with HDMI, this works with multi channel PCM, but I would really like to add a Processor.
post #4 of 5
Why can you not just send Multi Channel PCM via HDMI from the source?
post #5 of 5
If you would read my post you will see were I said, currently my source is the PC soundcard, although this works for HDMI multi channel PCM, I would prefer to use an advanced SSP as my source and bitstream DTS-MA to the SSP.
