AVS › AVS Forum › Display Devices › Screens › curved screen with rear projection?
post #1 of 8
Does anyone know if it is possible to do a rear projection setup using mirrors and still be able to use a curved screen. I know curved screens are mainly for A-lens distortion and with RP the distortion would be in reverse, but I was still hoping there would be a solution.
post #2 of 8
The nature of the problem would require the curve to be backwards (bowed out in middle on the viewing side). And the rear projection materials are usually rigid so that's a problem, too.
post #3 of 8
Is there a way to create barrel distortion for such a setup?
post #4 of 8
You could have a custom lens made if cost is not a factor. Otherwise, not that I know of.
post #5 of 8
In the world of simulation, rear projected curved displays are fairly common.
They are done with edge blended groups of projectors and a lot of processing power behind the image and a willingness to tailor and re-scale content, and abandon, twist, and manipulate the addressing of pixels, all sorts of techniques, to get images looking good. Acrylic substrates for "semi-rigid" screens are common, and can be "cold formed" into spectacularly immersive displays. Nice long throws and high value added mirror systems are used.
These sorts of displays are not "Home Cinema" purposed, they are for problem solving, architectural planning, and training. So the functionality is totally different. I'm certain that a rear projection curved screen home cinema display is quite possible, but it would need to be a partnership between a screen manufacturer, a projector manufacturer and a skilled integrator, all funded by a patient and deep pocketed customer. Its a nice engineering challenge, but nobody is going to want to do it inexpensively. There are many hours involved in crossing all the "T"s and dotting the "i"s.
post #6 of 8
Is it something like this?
youtube.com/watch?v=Lz0MH3uoBLs&feature=plcp
Forum rules don't let me post links, you have to see it the old fashion way.
post #7 of 8
Yes but picture that at a 6 or 8 foot image height with better edge blending and uniform color accuracy across the whole display.
post #8 of 8
At that size the immersion would be incredible.
  Back to Forum: Screens
