AVS › AVS Forum › Video Components › Home Theater Computers › Static when going from full screen?
post #1 of 4
Been using my htpc for a couple months now and things seem to be going well. Only issue that I am having is sometimes when I try to minimize wmc from full screen the screen goes completely static. I have to turn off the computer and unplug it so that it won't restart in static again. Does anyone know what could be causing this? I have done a search and didn't see anything like this before. Any and all help is appreciated.
post #2 of 4
Probably HDCP handshaking issues. You could try switching inputs on your TV and/or AVR to knock some sense into it.
post #3 of 4
Ok so that is what handshake is, that come up a few times in my searches but wasn't really sure that was what was going on. I will try to change inputs and see if that works.
post #4 of 4
It might be as simple as toggling from one input back to the HTPC's input.
Also, I've solved some handshake issues by minimizing WMC and then restoring it. I just have my remote programmed to send a minimize, delay, restore (start) command.
