AVS › AVS Forum › Audio › DIY Speakers and Subs › How are you guys finishing your Baltic Birch projects?
post #1 of 5
I finished by subwoofer...baltic birch...it came out pretty nice, but now i am going to try and not screw it up with a crappy stain job.
Pictures and technique would be appreciated...thanks!!
post #2 of 5
Some people use a stain with clearcoat and many use various finishes of black. Some even use bedliner textured black. I'm starting a plywood pair of boxes next week and it will probably go black with a clear finish but I'm not going for piano glossy black lacquer. I have considered using a fomica type laminate because it is so durable and relatively easy to apply. My room thus far is all utilitarian and I want the speakers to disappear so black is my choice.
post #3 of 5
I recommend practicing on scrap pieces first.
Lots and lots of uber-fine sanding.
I use a pneumatic sander, polisher, air gun.
Marine quality woodboat supplies is ideal.
post #4 of 5
Might want to try applying stain per conditioner before staining your samples. Helps to evenly distribute the stain so it doesn't get blotchy.
post #5 of 5
Shellac rubbed down to a satin finish with synthetic steel wool. With miter joints so the plies don't show and hardwood lumber edges for accents.
_Definitely_ experiment with scrap first.
