And whatever other tips to be had.
So I just got 5 new speakers for our 5.1 surround system and I was wondering what YOU would do with the surrounds in my situation? Or any other set up tips?
Setup is
sony 55" lcd
Yamaha rx-v565 receiver
Polk tsi400 fronts
polk cs10 center
polk fxi4 surrounds(bipole dipole switchable)
velodyne dls4000r sub
All speakers crossed over at 80 hz.
As you can see, the left surround is significantly further away than the right. What would you do? Bi pole or dipole mode? Where would you mount on side wall? In the pics the surrounds are currently only a foot from the wall which is in line with the listening position but obviously the left channel reflection point is way off from the right. Ideally I'd like to use dipole mode because I like the effect, but the left channel is weak even when setup with ypao since its reflection point is so far from the listening position. Could it be mounted further ahead on the left wall to try compensate? Or should I set them up so that the surrounds face each other behind the couch and the other set of drivers face the front? Other suggestions? The couch is centered in front of the tv for front to back reference. Sub is front firing and visible behind the front right speaker firing into the back alcove wall. Little to no acoustic treatment other than room furnishings and a small piece of acoustic foam against the wall the sub fires into. And a rolled up sleeping bag I put in the other corner of the alcove seen behind the xbox for an impromptu bass trap. lol Don't worry, I didn't 'actually' think this would help. Just playing with things.
Setup is
sony 55" lcd
Polk tsi400 fronts
polk cs10 center
